Nastran Incad hydrostatic loading on curved surface.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Greetings,
I'm new to this program, but I can't get the correct hydrostatic loads on a curved surface. I made a simple test which is shown below. It has a 10 inch radius and is 10 inches wide. The water is applied to the curved surface and the water surface is at the top of the piece.
Hand calcs show that the lateral force on the piece should be 18.1 lbs and the vertical force 28.35. The vertical force can also be found from the displace volume in water. The results from Nastran are 19.1 lateral (close)and 24.5 lbs vertical. Constraint 2 has very low reactions as it should since the resultant should be through the center of the arc surface, which is the location of Constraint 1. This is using the Quadratic Option. When I run it with LInear equations it has no apparent applied loads. When I run it with the Linear option it gets lateral reaction of 18.7 (not too bad) and vertical of 21.8. (Way off).
Am I doing something wrong? It seems like this should be an easy to accomplish loading. The documentation does not seem to discuss a vertically curved surface for pressure loads.
Thanks, for any advice.
Dave
Test model 10" radius 10" wide in water.
