- Mute
- Permalink
- Report
Hi All,
I am using Nastran 2024 and have an issue with locally refining mesh. When I apply a mesh control and then generate the mesh it does not change the mesh size. At first, I thought it was a visualization problem but have realized it is not changing the mesh for the analysis.
I have this issue when using solid elements or shells. Recently working on a shell element, I created a point from a sketch to apply a load to it. I then used the mesh control to create a node at that point however, it does not change the mesh in this area and when I run the analysis it says "Could not find a node to apply a load. Please check FE mesh and loads!"
Is there something I am missing when creating mesh controls or is this a bug in the software/a corruption of my software?
Thanks.
