Hi @John_Holtz
Thank you for your questions:
* That mesh is very coarse. Try to get 3 elements through the thickness of the spring.
I have made the mesh finer
* What are the material properties?
Type: Hyperelastic
Sub Type: Polynomial
Simple Tension / Compression
| Stretch | Stress |
| | MPa |
| 1.1 | 0.2 |
| 2 | 7 |
| 3 | 20.8 |
| 4 | 42 |
* Where did you get the material properties? (Another customer told me that material properties for hyperelastic materials from manufacturers are rarely suitable for simulation. You need to have the material tested by a lab that specializes in simulation to get properties that will work.)
Supplier data sheet
* How is the part restrained so that it does not move in X, Y, or Z? (whatever the left-to-right and back and forth directions are). I would not rely on friction to hold the piece in place and be able to converge.
Constraint 1 - Top face, fixed. A displacement load is applied to this face, to compress the spring.
Constraint 2 - Bottom face, fixed
Constraint 3 - Bolt hole, fixed
Constraint 4 - Side faces, symmetry
* What is the contact type?
Type: Surface to Surface
Contact Type: Sliding / No Separation
Penetration Type: Symmetric Contact
Stiffness Factor: 1
Penetraition Surface Offset: 0
* What warnings occurred in the analysis?
Warning E5074: No Convergence in maximum number of iterations permitted
Fatal Error E5076: Maximum number of bisections permitted reached
* How many increments are you using? (I suggest a minimum of 20 steps for something like this.)
Thanks, I have changed it to 20
* Where's the model? It will answer all the other questions reader have and enable readers to try different settings.
attached
