Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Hyperelastic Shell
1 REPLY 1
roger_coxNUKZV
81 Views, 1 Reply
Hyperelastic Shell
Nonlinear Static Deformation Analysis
I'm modelling a thin part made from a hyperelastic material.
With Tet elements, it crashes when I reduce the element size or increase the displacement, so I believe that it should be modelled in shell elements.
But, with shell elements, as shown in the figure, it only runs if I change the material to Isotropic. With the Superelastic material I get:
FATAL ERROR T2027: NON-COMPATIBLE MATERIAL
I'm looking at a high strain on a material that gets a lot stiffer at high strains, so an Isotropic material is going to give unrealistic results. Any suggestions please?
Labels (1)
1 REPLY 1
John_Holtz
in reply to: roger_coxNUKZV
Hi @roger_coxNUKZV . Welcome to the Inventor Nastran forum.
The thickness of shell elements does not change in a nonlinear analysis. (This is probably why the hyperelastic material model is not supported.)
Since the part is not that thin (10 mm thick for a 60 mm "diameter" tube) and a hyperelastic material is required, you should use a solid model for the analysis.
John
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius :winking_face:
