Exclude Feature from analysis
karthur1
Mentor Mentor
Message 1 of 8
karthur1
Is it possible to exclude a feature (hole or extrusion) from the analysis just for simplification?  We had the ability in the Inventor FEA to do that.
Replies (7)
Message 2 of 8
Jon.Dean
Hi @karthur1,
You are correct. In Inventor FEA you are able to exclude features from the study.
In Nastran you are not exposed to the features, so no way of excluding them.
Cheers
Jon.
Jon Dean
Message 3 of 8
shigeaki.k
Hello @karthur1 ,
if you are working with assemblies, the other option is to try "shrinkwrap substitute" representation. Please note that this workflow needs to be applied to the top assembly.
Video: Using Shrinkwrap Substitute with Autodesk Inventor Nastran
There is a known issue where existence of "shrinkwrap substitute" representation in the sub-assemblies causes AIN (Autodesk Inventor Nastran) to crash.
Shigeaki K.
Shigeaki K.
Technical Support Specialist
サポートとラーニング | Support & Learning
Message 4 of 8
karthur1
@Jon.Dean wrote:
Hi @karthur1,
Cheers
Jon.
Not really what I wanted to hear, but it is what it is. Would be a good feature to have (future plans maybe). On some parts, this reduces the time it takes to run the analysis.
Message 5 of 8
shigeaki.k
Hello @karthur1 ,
could you submit that idea to Autodesk Inventor Nastran IdeaStation here?
Shigeaki K.
Shigeaki K.
Message 7 of 8
shigeaki.k
@karthur1  Great! I have voted for it.
Shigeaki K.
Message 8 of 8
jonathan_honeycutt256PK
Instead of excluding the features from the study, simply suppress them in the model. Nastran boasts about the ability to make changes directly to the model without leaving the analysis environment. With inventor stress analysis, anytime I wanted to make a change other than "exclude from study", I would have to exit out of the study, make the change, and then open the study back up, which took extra time.
