i want to transmit a torque into a hole by a 1D Bar-element. The hole surface is connected to a point in the holecenter (rigid body connector) as shown in the pictue attached. I implemented the line-element with an extra sketch, starting point at the centerpoint. Processor is solving but do not give any results.
Im working with Inventor 2016 and Nastran in CAD 2016
Output gives the following warings:
Warning: T2061 Unreasonable Material Data
Warning: E5010 One or More non-Zero Degrees of Freedom were Auto-constrained
I think it is a DOF-problem or a problem with the sketch? I hope somebody can help?
much thanks!
Solved by Roelof.Feijen. Go to Solution.
Hi @Anonymous,
Warning T2061: Unresonable Material Data should not be the problem.
Causes:
WARNING: E5010:
Do you have contacts defined in your analysis?
If so. Is it a manual contact that is being set to Auto?
Can you otherwise share your model? From the picture it is hard to tell whats wrong.
There are no contacts in my model. Just one part mixed with a bar.
after deleting shear modulus Nastran give me results. I did not expect an error caused by material properties. I thought the problem would be due to the degrees of freedom or a fail in meshing.
Thank you!
