Assembly with multiple Composite Laminates
salil.phatakFKEGW
salil.phatakFKEGW
I have an assembly with multiple composite parts. Each part has its own laminate sequence. When viewing the results, how can I check ply status within each part separately? Part 1 has 11 plies, part 2 and 3 have 14 plies, part 4 and 5 have 15 plies. When viewing results, I can see status for 15 plies, but I can't see which part the ply belongs to.
Thanks.
John_Holtz
Autodesk Support
Autodesk Support
Hi @salil.phatakFKEGW
If they are separate parts and created as surfaces in the Inventor model, then you should be able hide the parts in the Nastran results. "Results > Options > Part View" tab and select the part you want to display.
Also, viewing the results of ply 15 will show a result of 0 for parts that do not have ply 15. Therefore, you do not really need to hide the parts in order to know which parts have ply 15.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
salil.phatakFKEGW
Thanks John. I was only looking at ply status for a non-existent ply which showed "not failed" and didn't see that the stresses were 0.
I'm currently using 2022 and will update to 2023 soon.
Thanks.
