Tube&Pipe 108: “Allow Hoses to Start Both Ends”
Allow hoses to be started both ends. Once you start route command on a hose you need to keep going (add nodes, segments, etc) and then click the very other end. Just like normal pipes I need to start one end, then the other end and then worry about how many points and nodes I need to have in between. As soon as I route between 2 open nodes the hose closes and the segments become tangent (continuous hose, not kinked). Furthermore if a single end has been started (as mentioned) you can’t add any more routes, the route button becomes locked. When copying Runs or testing various iterations it’s necessary to create a new route and then delete the old one. I am now forcing the old hose route into construction line so I can do a new one in the same route. BTW: There’s no delete on right click contextual menu on sketch only segments but delete key works.
@dan_szymanski
