When using 3D Move Rotate command on nodes the rest of the sketch segments should stay in place. Even if the sketch is not fully constrained, the rest of the nodes should keep position while the segments of the node should adjust, no matter the direction of movement. I am actually moving along the route and I don’t see why the rest of the route should change. As a temporary solution I fix adjacent segment, do the drag, move, then remove the fix constraint.
@dan_szymanski
