TAB-key toggle beteween Horizontal and Vertical when either is selected.
When having vertical constraint or horizontal constraint selected in the sketch environment have the TAB-key toggle between both.
5 Comments
jesserop
If you want this because you (like 99% of inventor users) select the wrong one all the time, I suggest you to download the "sketch plus" tool in the autodesk app store. It automatically recognizes if the point / line should be horizontal or vertical depending on the relative location to each other.
Yijiang.Cai
Status changed to: Accepted
Many thanks for you posting the idea, and tracked as [INVGEN-721].
Yijiang.Cai
@Brodholm @jesserop
we are investigating on this idea, and some progress is made. You can access the feedback community page to see what we have done
You could access the page below to understand how to join the Beta at https://forums.autodesk.com/t5/inventor-forum/inventor-feedback-beta-project-how-do-i-get-access/td-...
River
dennis.schaperAKPCJ
This sounds a bit like the horizontal en vertical constrains of Fusion360. Just one button and the only thing you have to do is draw vaguely in the correct place/orientation.
I've also taken en look at the Sketch Plus tool and the idea of also merging the parallel and perpendicular constraints are also a very good idea! This saves two buttons and a lot of wrong clicks.
Yijiang.Cai
This idea has been implemented within Autodesk Inventor 2023.1. Please review the Inventor 2023.1 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
