Please Add to the Hole Feature tool, Slot, Hex and Square Holes.
Reason: The hole feature has a few benefits over other methods of creating shaped holes and would really increase the friendliness of the program for the users. It is often over looked b/c you can do most of the stuff hole feature can already do using sketches and using the shapes there... But Hole Feature is better b/c it uses allows the use of automatic Hole Tables. And it also can provide recommended hole clearances for various sizes fasteners. It's just much faster and simpler too. Currently we are using punches in sheet metal to help us remember what the hole clearances are. But Punches do not function the same way as holes. Not to mention if you don't include custom sizes in those punches and now you have to delete the feature. Where-as the hole tool you can just edit the feature and easily adjust as needed. Plus the constraints are easy too.
I think it also works better with iMates but I could be wrong.
Example of Holes
This suggestion kinda duplicates the Hole Feature request for Slots as seen in all these links. But this expands on their requests to other commonly used shapes.
As a benefit for all the ideas... This gives Autodesk Developers more reason to work on this b/c they can sit down and work on this chunk of work all at once. It does need attention as shown below... I'm sure there's others.
