Show only
Search instead for
Shouldn't Inventor know that this is a cylinder and should therefore have a diameter symbol? Let's have it pop in there on its own without me having to do an edit text operation on it and manually add it.
In drawings if use dimension of diameter symbol of diamater is automaticly added. But if you place symbol of diamater in dimension edditing is not the same symbol. See you in picture.
There is a way around it, but Inventor should be able to identify in the drawing what is a circle or not from the model.
I've been using retrieve model annotations for many of my drawings for the last 2 years and it's amazing, you can even change the dimension in the drawing and the model will change so I would suggest trying that!
Can I add to this with the diameter being added on dual dimensions the Diameter for the dual dimension cuts into the bracket which looks very unprofessional.
Some possible solutions for this idea are currently under discussion on the NDA based Inventor Feedback/Beta forums. If you would like to contribute to the discussion, please apply for access using this link: https://bit.ly/InventorBeta
I get a 403 Forbidden in the link to the beta forums, I guess you have to be on the beta program to enter?
It would be great if this issue could be rectified, it is particularly painful when putting multiple diameter dimensions down on section views (which is often the clearest place to put them) where there is no "diametrical line" to select as on an un-sectioned view. It is doubly frustrating that "copy properties" does not work to change between linear diameter and standard either.
403 Forbidden typically means that you have stale logon credentials cached in your browser. If you clear your cache (ctrl+shift+del) or use private/incognito mode then you should be able to log on.
Hi, I know it doesn't belong in this idea. Please vote if possible. The customer bought licenses for 87000 euros and Inventor does not have this functionality. I care very much about it. Thank you for any vote, if you can hear me.
