キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
Sketcher again!
Sketcher again!
Another sketcher issue (I cannot find a logical reason of current sketcher TRIM command). Let me explain. make a circle, draw a line fron the center of the circle at a given angle but longer than the circle radius, dimension the angle of the line and, say, the X axis. then TRIM the line up to the circle, the dimension IS LOST!!! SOLVE THIS!  ans this is just a poor example. this behaviour occurs everytime you trim something what was previously dimensioned/constrained!
3件のコメント
mflayler
Maybe you could post your steps on this and which version you are using.  I just tried this in 2014 and it keeps the Dimension without fail.  This might have been an under the hood enhancement in 2014 because I recall having more problems with TRIM in the past.
A_Sima
one simple example
I attach a picture of a sketch in different steps. yellow rhomb in places of dimensions which the system erase, red hexagon, the dim that stays even the trim was done ... different behaviour. IV Pro 13 (it sounds better than 2013:D )trim.png
inv.ideareview
変更されたステータス: Archived
Thanks for sharing your Idea. The product team continually reviews this forum aiming to deliver in the most impactful way we can based on voting. We also regularly examine the list to make sure it reflects the most current Ideas. As part of this process we archive old Ideas that haven’t received broad support. This ensures there is room for new Ideas to be reviewed by the community and for the most relevant and meaningful ones to gain votes.
This Idea is archived because it's been on the board for over a year and hasn't received many votes. If you want to raise it again and try to gain more support across the community, you're welcome to do so. Leveraging images, animated gifs or sample mock-ups can help convey concepts and generate more votes from other users. If you have questions or see a connection between this Idea and others that should be accounted for, please let us know.
- INV.IdeaReview
お探しの情報が見つからないときは、コミュニティで質問しましょう。困っている人がいたら、情報を教えてあげましょう。
アイデアを提出
