Sheet Metal - Hem for Multiple Edges
I'd like to create four side, but we have to do it one by one. Hopefully we could select four side at once.
14 Comments
JDMather
http://forums.autodesk.com/t5/Autodesk-Inventor/Hem-in-Corner/m-p/4344854/highlight/false#M477836
@JDMather - This reply has been edited by the moderation team as the legacy links were no longer valid
Although implemented, this feature need minor improvement, allowing to hem multiple edges at once. Of course there's several workarounds already discussed on Inventor forum, but none is as convenient as having a dedicated button with 2 or 3 dialog options to choose from and OK to execute.
Ben-Cornelius
so if currently if you want a hem with miters you have to set it back from the ends one at a time then use corner seam. You should be able to pick all edges with automatic corner seam conditions the same as flange does
maybe at moment that is the best that we can do by selecting one edge to others..
Problam same
It would be great if we can do it at once. Great idea @novly.abdurohman
jyager
A hem A.A. is a fairly common HVAC practice for patches or generic stiffening of a piece of steel...with the corners typically mitered. It's silly that this isn't already a function.
Ben-Cornelius
khalidelrefai
I suggest to Adding the following options to Hem feature in sheet metal environment:
  1. selecting multiple edges or loop select mode, also applying Miter automatically when Hem intersect.
  2. adding corner tab to Hem window for corner treatment optionsAutodesk Inventor Hem.png
Tags (1)
dan_szymanski
Idea added to backlog for future consideration [427]. Thanks!
4 Years and still nothing huh, what a "future consideration"
seagrotek
고려한지 4년... 지쳐갑니다.
dan_szymanski
Some possible solutions for this idea are currently under discussion on the NDA based Inventor Feedback/Beta forums. If you would like to contribute to the discussion, please apply for access using this link: https://Autode.sk/InventorBeta
dan_szymanski
Status changed to: Accepted
