Show only
Search instead for
Hi, I really appreciate the interest. Very please this link is context. Creating this functionality would be very easy for you and would help us users a lot. Follows up on this topic. Please also consider this link. Thank you very much for your work.
When the retrieve model Annotation is sophisticated, then efficiency will increase. In this I see great help and efficiency. Now I create a model and dimensions, and then I have to re -create the dimension for the second time in the IDW drawing. New behavior = I would only create dimensions in the model and project them into the drawing. Other functionality is very important. I have a problem to distinguish manually created dimensions in IDW and projected dimensions using the retrieve model Annotation
I have 30 items. I have to make 9 sheet metal details in one drawing, for firings. The Retrieve Model Annotations functionality does not work - it is not supported. When will this option (support) be available? Each sheet metal has its own dimensions and I have to re-create the dimensions that the model contains over and over again. I've been waiting 5 years for efficiency improvements and nothing. Please can you improve this functionality as soon as possible?
Functionality only works for 1 ipt and drawing. Not for weldment and detail.
The drawing of the sheet metal views is then made into dxf
