Replace Model Reference .ipt to .iam
Let us pick assembly files too at replacing references.
16 Comments
SharkDesign
Sorry I can't delete my comment, I read your suggestion wrong.
Andrew2803
@SharkDesign, never mind 🙂
can you please!!! do an improvement on idw,
 so that user will be able to swap reference file type from ipt to iam or vise versa.
Tags (1)
NachoShaw
Hi
I have actually made a tool for this. I browse for the new part (doesn't matter if its iam, ipt or ipn) and then create a new sheet with the replaced reference file. I use it for when I have variations of parts / assemblies and I want an identical drawing sheet layout but with the new referenced part
Nacho
will you share it? i want to test it if it works for me.
DRoam
DRoam
Hi @Anonymous and others. This has actually been requested before. Please consider voting on the original as well to help get this suggestion recognized: Replace Model Reference .ipt to .iam.
Please! We plan to use the assy drawing as a machining drawing and an assembly drawing.  The only difference is 2 small threaded inserts.  This was a last minute change to include the inserts so I need to point the .idw to the .iam model instead of the .ipt model.
Andrew2803
Annoyed me a lot too in past, I'm with you @geatgirl2951 😉
gusi_cl
It may be more useful if it this command is able to sostitute .iam or .ipt whit both kind of model. See the imagine below.Cattura.PNG
Andrew2803
Duplicated idea:
https://forums.autodesk.com/t5/inventor-ideas/replace-model-reference-ipt-to-iam/idi-p/6405839
In comments there are some related topics as well.
MikeKovacik4928
I also would like the functionality of replacing in idw, iam with ipt and vice versa.
I have found a workaround for replacing iam with  ipt
see https://forums.autodesk.com/t5/inventor-forum/replace-model-reference-iam-with-ipt/m-p/7679140#M6764...
replacing ipt with iam, not too sure, but I'm sure someone out there has found a way.
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
Yijiang.Cai
Many thanks for posting the idea, and tracked as [INVGEN-67633]
Yijiang.Cai
8 years later and Inventor STILL doesn't allow this functionality. Which means I get to re-make an entire drawing from scratch for adding a threaded insert to a molded part, changing it from a part file to an assembly file. Crazy.
dan_inv09
brandon.rodriguezN68U2 - That is exactly the problem I came here to find a solution for!
