Quick Color Scheme Change
Current Process to change Color Scheme:
In order to change the color scheme from when I am working on a part to when I want to take a screen shot or quick render for presentations or emails you need to go to the Tools ribbon, Options bar, Application Options button to open the Application Options window.
In the Application Options window select the Colors Tab and change the selected Color scheme  and under Background change the drop down selection. I tend to switch between "Winter Night" Color Scheme with a "Gradient" Background style and "Presentation" with "1 Color" for the Background. I change between these two since the darker background with "Gradient" helps when doing CAD work and sketches while the "Presentation" background with "1 color" is best for taking a screen shot of my progress for a quick presentation or email.
Requested New Process:
Rather than doing this long process for changing the Color scheme and Background I would like some quick toggle to change these. It would be nice if I had two saved schemes (Color scheme and background saved as one) that I could quickly toggle between. Either a shortkey I can press on my keyboard to cycle between my saved schemes or a button on the ribbon or in the option below the View cube.
15 Comments
ilotey
I wish for this feature everytime I need to take a screenshot for a presentation or email
russell
Yes this would be a very helpful option.  It could be included in the right mouse context menu
Yes to this. A keystroke combination would be ideal for me to switch between grey where I do my design work, and white for image export for presentations.
m.stricklandKB5FB
Also flagging interest in this feature. Constantly pulling screen-grabs out of inventor and I want a clean white background for those, but do value the easier-on-the-eye gradients for normal use and want to keep that ordinarily. Just want to be able to quickly toggle between the two when needed; and agree a keystroke combo would be the neatest and best option
henry.langner
Observer
Same here. Please make a simple toggle option!
jdowiak
Great idea, casting my vote of interest as well.
hubert.vdm
Please add a toggle button on the quick access toolbar to switch between current user background, standard black background and a white background.
This will be very helpful for screenshots and presentations.
Thanks.
henrikubbe4438
Bump, ping and sign me up! Missa Wanna 'dis feature!
j_grootjebbink
i know it is not what you're looking for, but my college fixed it with the following Ilogic:
If ThisApplication.ColorSchemes.BackgroundType = 52738 Then
	ThisApplication.ColorSchemes.BackgroundType = 52737
Else
End If
maybe it helps in the short run for you.
i use it alot for screenshots 🙂
kwilson_design
I use CoolOrange Screengrab app/add-in for this. Just an FYI to the OP (and others) if weren't aware an app exists for it. You can make it compatible with any version of Inventor with a simple text edit, so don't worry if it shows it isn't compatible.
 https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=99891395473620492&appLang=en&os=Win64
Yijiang.Cai
Many thanks for posting the idea to us, and tracked as [INVGEN-75701]
klfh4YUHK
Observer
Agree, i miss the same function. For screenshots for emails and even more for printing, it's a waste of ink to print a dark background.
dan_szymanski
Status changed to: Accepted
Accepted idea [INVGEN-75701]. Thanks!
henrikubbe4438
@j_grootjebbink:
Else
End If
i use it alot for screenshots "
Can you find a list of what the different numbers represent?
On my machine it only gave me same color, but gradient. Not usable.
EDIT: I found this, it does what I want:
    If (ThisApplication.ColorSchemes.BackgroundType = 52737) Then
        ThisApplication.ColorSchemes.Item("Millennium").Activate
        ThisApplication.ColorSchemes.BackgroundType = BackgroundTypeEnum.kImageBackgroundType
    Else
        ThisApplication.ColorSchemes.Item("Presentation").Activate
    End If
dan_szymanski
This idea has been implemented within Autodesk Inventor 2025.2. Please review the Inventor 2025.2 What's New article here, for more information regarding how you may leverage it. Special thanks to everyone who cast a vote for this capability.
