The print configuration needs to be saved per DWG. It's fine, if all I print is one size, but if I need to switch between different sizes, Inventor always seems to default to an A size sheet. It should be similar to that of how AutoCAD saves DWG print configurations per DWG. Sometimes it just takes to much time to setup the print configuration, especially if you have to switch between printing a A size sheet on a regular print, then print a D size print on a plotter and having to change setting on a plotter in order for it to print correctly. In the short term it's not all that long, but in the long term, all that time you waste inputting printer configurations adds up.
