possibility to compare parts
It would be very useful to have the possibility to compare different versions of a part.
Compare Volume, compare features... compare iproperties
Manu
31 Comments
kohler.johnson
I and others on my team would appreciate a built-in tool to compare parts.  Currently we have to place two parts in an assembly, make them different colors, and attempt to show differences by taking cross-sections at various points.  Other CAD packages have this ability, and it would be a beneficial addition to Inventor.
ckuester
in my view it would be very nice if two different versions of a "vault part" could be easily compared, perhabs even "vault Assys".
Greetings
Christian
DRoam
In the meantime, there are a couple of ways you could do this.
1) Place both parts in an assembly and use the "Analyze Interference" tool to visually see what's different between the two parts, like this:
2) Place both parts in an assembly, save the assembly, then create a new part and use the Derive tool to derive the Assembly into your part. You have a number of different options from here. You can use the 'Subtract' option to see only what is unique about one of the parts; or you can use the 'Intersection' option to only see what is identical between the two parts.
Use the interference detection tool while the two parts are overlayed.  It will create a shape of the difference, give you a percentage, and such.
damiendefrance
A comparison tool would be a very good functionality to implement !!! Smiley Happy
This is indeed a really good idea. espacially when there are two complex parts, where the only difference is a hole which has in one part 20mm from the edge and in the other 20,5.... can take a few minutes until you see the difference.
so this function would be very useful... !
@Anonymous
Easy solution that takes a few minutes:
1) Place the parts to be compared in an assembly and constrain them by features that did not change. (verify!)
2) Save assembly.
3) Create a new part.
4) Use "Derive Component" command and point to the previous assembly file.
5) Use the Boolean operations to subtract one part from the other and spot the differences immediately. (if you are subtracting one another and see nothing in both cases, there are no differences).
It takes less to do it than it took to write these instructions... Smiley Happy
This is really a good idea, we can compare two parts/assemblies and highlight similarities with one color and dis-similarities with other. Then we can take snaps and show them in presentations
May be a better representation of "Analyze Interference" command
fsanchou
Also, it would be nice to compare 2 Vault revisions of the same file.
And I add to be able to compare 2 assemblies (parts modification, new part / remove, ...)
kdomkus
I've been getting parts from another vendor who is using Solidworks. After importing, I sometimes need to see what changed. It would be nice if there was an easier way. Especially when trouble shooting a complex part to see what went wrong.
..Cass
In my current study, I want to compare two 3D model between them and I don't found exactly what I want ...
When I worked on CATIA, it was possible to have comparision between two assembly, two parts or other configuration, and I see all differences with differents colors (yellow : no difference ; green : new version ; red : old version)
Can you help me about this subject ?
Thanks.
Torben.pedersen
I want to use this to, I think Soildworks have this feature
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
Aadithya01
Hey Guys,
This is a long time request of some of my customers who were requesting for Inventor's ability to highlight version comparison . Atleast with one previous version. On the top of my head I don't remember that this feature is provided by any of our competitors. Also I was told that version comparison is brought into AutoCAD 2019 ...
Requesting for a similar capability in Inventor Pro as well in the future releases having the ability to compare two different versions of a part or a assembly or drawing recognising the editing made with features and if parts were added or removed in a assembly which this feature must clearly point out
If you like this idea kindly hit "Kudos".
Regards
Aadithya
Application Engineer
USAM Coimbatore - Autodesk Gold Partner
Tags (1)
jtylerbc
For drawings, Design Review can compare an old and new DWF file.  This isn't as comprehensive as what you are asking for, but I mention it as something that might help with some of your needs using a tool that is already available.
Aadithya01
Hi guys
The interference method like @DRoam suggested is good with parts . But what about assemblies ?
Regards
Aadithya
Hi Aadithya01,
Yes, his method will work with assemblies as well. You will have to derive the assemblies into parts first and have these into an assembly. Now you have to derive this main assembly and perform the Boolean operations or just interference detection, whatever your goal is.
Please let me know if you've got my message, I am responding to the e-mail.
Adrian (asiu)
Aadithya01
Hi @Anonymous
Sure I will try this method ...  I think this will work
tmueller6RR3D
A "compare part" feature is long overdue. Even better would be the capability to compare multiple parts in assemblies. We create lots of simple flat or formed sheet metal parts, that are very similar to other components that may have already created (often during copy design), and may have been able to be reused. Designers often find it easier (or safer) to recreate in the case something "may" change. This does not take into consideration the downstream time savings in manufacturing (stock quantities, burn, saw, form or other operation programming and routing).
It would be great to be able to compare two assemblies, or a single assembly against a library of parts and identify parts that are identical so that parts can be reused where practical.
Perhaps we could even tap into vault to identify potential duplicate parts.
Tim
