I use ordinate dimensions on most drawings. Before 2023, if your bottom left corner was a radius, or 2 flanges, you could touch the vertical and horizontal line, then where the intersection point would be to set your ordinate Origin.
After 2023, this was removed for some reason.
Now I have to go into the model, measure from one edge to the other, put the origin on that edge, the manually edit/move the origin by the measured distance.
This is just asking for error and also makes what used to be a 1 click job multiple steps.
I don't know if something else with 2023 changed this unintentionally, or if this has been noticed. I can't imagine it would be removed on purpose, but it adds time and potential error with no benefit. Is this being worked on? If not, can you change it back to how it was before Inventor 2023?
