Model States: Capture Text parameters in the Model States table
Text parameters can be a crucial to the operation of some workflows and add-ins. Text parameters can vary from component to component, and the purpose of Model States is to have multiple components in a single file, easily sharing similarities while capturing differences. Therefore, Model States should be capable of capturing this important potential difference between Part/Assembly documents.
Please add support for capturing Text parameters on a per-Model State basis, so we can take advantage of Model States for workflows and add-ins that rely on these parameters.
9 Comments
petestrycharske
This is also true for Boolean parameters.  They potentially require unique values per Model State as well.
DRoam
Wanted to add, the main reasons I care to use a text parameter at all, instead of an iProperty, are these:
  1. We can create multi-value Text Parameters and put them in an iLogic form to let users choose from a drop down list. This isn’t possible for iProperties. Idea here: Custom iProperties - add list type
  2. We can respond to the change event for a specific parameter in iLogic/the API. This isn’t possible for iProperties. Idea here: API/Add-Ins: OnPropertyChange event
If both of those were implemented for iProperties, I would be perfectly happy with (actually prefer) using text iProperties rather than Text Parameters for the uses I’m using them now.
Yijiang.Cai
Status changed to: Accepted
It has been tracked as [INVGEN-34850]
NachoShaw
The exporting of said Text Parameters too. I use Text Parameters and need to write code in order to get out my text parameter values.
This really needs to be implemented.  I hate that it works in iLogic but not in iPart.  I have so many parts that show the stamping and I have to create a new feature for every part number stamping.  I should be able to just at the text parameter in the iPart table.
Yijiang.Cai
This idea has been implemented within Autodesk Inventor 2023. Please review the Inventor 2023 What's New article here. Special thanks to everyone who cast a vote for it.
mfoster9TD82
Was this only implemented with text and bool parameters, or with number parameters too?
Yijiang.Cai
Numeric parameter captured was supported in Inventor 2022. @mfoster9TD82
mfoster9TD82
@Yijiang.Cai , does it capture the calculated value of a parameter?
It doesn't look like 2023.2.1 does.
https://forums.autodesk.com/t5/inventor-ideas/calculated-parameter-values-in-general-tables-model-st...
