Make Tables similar to Excel
We require Excel to use Inventor so why don't Inventor's tables work the same as Excels?
e.g. (off the top of my head)
  • F2 to edit the cell  (personally REALLY miss not having that)
  • when editing the cell with F2 have Ctrl+left/right to skip words
  • Enter to finish the cell and alt+enter for a new line within the cell
  • merge cells?  (not sure the need, but would help with copy/paste betwen Iv and Excel)
  • borders like Excel
also, while talking about tables - line-breaks in titles, is that in yet?
19 Comments
My hope is that this is implemented both on the user side and the api side.  Right now the api for a table is worse than terrible.
Hopefully tables will support features like strikethrough, bold, underline, etc for text within them.
dvsmiller9
Text wrapping in headers would be nice.
dan_szymanski
This project [US-169637] is under review by the development team.
dan_szymanski
Status changed to: Accepted
Accepted idea [US-169637]. Thanks!
Would be nice to add colums w/o having to make a header or even merge cells together.
basically anything you can do in excel you should be able to do in the tables.
I would like to see a custom parts list creator that includes all of the functionallity of Excel.
I like all of the automatic functionallity of the parts list command, I would just like the ability to customize it.
Tags (2)
Please give users the ability to lock row heights and column widths in drawing parts lists and tables.
Tags (1)
I am having the same difficulty.
There also appears to be a new behaviour in Inventor 2017 that alters the table row height in a drawing template when the template is used for a NEW drawing, causing the table to re-size itself.  If row heights were set by the user, rather than part of a formula set by multiple style settings, it would be possible to avoid this problem.
insert options in table creation feature with more cell format style for eg wrap text which we have in Microsoft excel.
dan_szymanski
We are refining procedures around idea status.  Changing this to Future Consideration.
teyink
Autodesk needs to add Excel functionality into their general tables for merging cells, text wrap, etc.  These are just basic needs to make the general tables usable.
Hunteil
Having that Merge cell feature would be real nice right now in my family table. 25 lines could easily be 5 lines.... So either I make a new table with no intelligence to update certain values automatically or leave it with 25 lines and have tons of repetitive data and piss off every person reading this down stream. 😕
Guess I'm making a custom table with no intelligence to update automatically to these values when they change.
And it would be nice to have it auto round these numbers so it could still be the same number so us engineers can return and see accurate numbers. Like 0.83485" but displays as 0.835" (This can be done in excel too). We use these real numbers to keep things live so we can come back and then only show the shop the rounded values...
Please add more functionality.
joshua.bergerA5Y5L
In 2020, we still do not have this available. To get one table formatted correctly, we are creating 4. That is the definition of (bad) workaround. This has been implemented by competitors, so it can't be that hard.
RYWei
8 years!
sunny_8848
支持合并单元格。
bbgustaf
We create allot of drawings that have multiple options. Allot of times within a specific product there are additional multiple options. As it is now we have to created Sketch symbols to create these Tables which is time consuming to create and edit them. It would be a HUGE bonus if we could import an Excel spreadsheet with merged cells into an Inventor table that allowed/displayed merged cells.
Inventor should support more possibilities of excel imported tables in drawings, like combined cells, so that the table on the drawing looks like the one in excel. (see attached picture)
Maybe also line weight and other appearance features.
Comment what you would also like to be possible.
Tags (1)
Yijiang.Cai
As to cell merging, this idea has been implemented within Autodesk Inventor 2025. Please review the Inventor 2025 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
WCrihfield
The current process of inserting an Excel table in a drawing is extremely archaic, because it lacks some of the most basic options and functionality that we all want.  It only ask us to choose the Excel file, specify a single cell address that represents the 'start' of the 'data' that we want in the table, and what row the column titles are on.  It does not let us specify which Sheet the data is on.  It does not let us specify the entire block of cells that we want to use...not even just an 'end' cell address, so if there is other data below, or to the right of the other data, it 'sometimes' grabs that also.  And if it grabs extra cells that we did not want, we can not delete those rows, columns, or cells from the resulting table...we can only 'hide' rows or cells.  Then, if something moves in the Excel file, it messes up the table in the drawing, and does not give us any way to edit that existing table so we can 'fix' it.  Our only option is to completely delete the existing Excel table in our drawing, then create a new one.  So, if I want to make a multi-sheet drawing, with on or more Excel tables on each sheet documenting a set number of variations of a single design, if all those excel tables are referencing the same Excel file, then all the blocks of cells have to be on the same sheet (the first sheet only).  And when one row or column moves, it will mess up every table on every sheet, with no way to fix them, except replacing them all.  About the only alternative is to create a separate Excel file for each Excel table I want to put into that one drawing, so that each block of cells is the only ones on the whole first sheet.  This is ridiculous.  Please fix these very basic functionality needs.
