Changing the visibility of a child part in an assembly from On > Off > On , resets the Part's View Representation back to "Master". The problem is "master" usually has all the working geometry of the part like sketches, planes, etc. This becomes very troublesome when you are working with skeleton modeling. It would be great if the View rep would be maintained even if visibilty is changed.
Example:
-Opened Assembly
-Set view rep of child part to "Default" within the assembly (1st picture)
-Turned visibility of child part off (2nd Pic)
-Turned visibility of child part back on (3rd Pic)
-View rep of child part is now set to "MASTER" showing all working geometry
-Manually change view rep of child part back to "default"
