Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Inventor Read Only and STEP format
it would be nice if "inventor read only" could read the STEP format. It would be even better if he could convert it like "DWG True view" with DXF Format.
Thank you.
10 Comments
L_S_
It would be VERY nice if  "Inventor - read only" could open ALL the  supported 2D/3D formats.
It won't break the read-only philosophy and will be very helpful to all those who don't need to actually modify, but only open & check the files they receive and then send them to the designers... I really hope to see this in future!
freesbee
"converting" would be probably against the Read-Only philosophy, but competing products (as for example eDrawings) offer the possibility to open and view STEPs and other 3D formats. The idea as formulated by LStradi8 should be definitely pursued by Autodesk. Thumbs UP
to open step files we are using additional program:  "eDrawings 2017"  thats easy but its an add program on the laptop.
Majjek
I also think a Read Only program should be able to only read different CAD formats.
I can understand that converting to an Inventor format would conflict with the read only philosophy.
That's why at least the read only possibility should be there.
It's already available as a free tool in the Autodesk Viewer, so why not add it here.
We're also forced to use the competitors software eDrawings, just because Autodesk doesn't support this...
dan_szymanski
Idea added to backlog for future consideration [58913]. Thanks!
john.browningGQ8YF
Community Visitor
please allow inventor read only to view step files
we currently use dss product to do this.
ChrisMitchell01
Status changed to: Accepted
This is currently under consideration for inclusion in Inventor 2025; if you would like to give it a try you can apply for Beta access using https://Autode.sk/InventorBeta
Chris
dan_szymanski
Yijiang.Cai
this idea has been implemented within Autodesk Inventor 2025. Please review the Inventor 2025 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
samer.kanaah
Can you please update this article :
Can Inventor Read-Only mode open step files?
