Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Gussets for Frame Generator
Have a quick and easy was to do gussets for frame generator
16 Comments
bverboort
Would result in a triangular plate based upon two or three faces/edges selected (or dimension or combination of both)
cadman777
We've been asking for this since 2002!
Just discovered the Frame Generator - very happy with it so far but the lack of a gusset design feature is a glaring gap in the program even to someone who's been using it less than 24 hours. Would have thought a gusset generator (could perhaps function similar to the Chamfer and Fillet features) would have been included a long time ago? Cheers.
brubakerp
I just found this while wondering how to do analysis with gussets in place.  Thumbs up for request.
dan_szymanski
Idea added to backlog for future consideration [11537]. Thanks!
dan_szymanski
Status changed to: Accepted
JamesLodge01
It would be good to see a tool that would allow strengthening ribs to be added along the length of I beams (joists) or channel maybe using the same / or similar profile used when notching. Reason being, sometimes when designing a frame, strengthening rib is required due to upper load. Yes conventional modelling techniques can be used to create and add such a model, but it would be great to see a Frame Generator tool that would help do this based on the inserted beam geometry and help speed up the process.
risc4000
We need it yes
dan_szymanski
We are refining procedures around idea status. Changing this to Future Consideration.
dusan.naus.trz
theme from 2013. Well I see that Solidworks realized Ideas from Ideastation 😞
https://www.youtube.com/watch?v=JEoxvezUDkA
pbVE3M6
Frame Generator hasn`t instruments for metal connection plate. I would like introduce to you features for design connection plate, how it is work with design accelerator components.
 Type I - plate between 2 webs
0. Select start plane.
1. Select start face.
2. Select second face or create thickness.
3.  Placement start bottom face connection plate
4. Create height dimensions or stretch up plate.
 Type II - plate placement in a corner of metal frame, for example between webs and chord.
1. Select start plane
2. Create thickness plate or stretch thickness
3. Select 1 face
4. Select 2 face
5. Create dimension A or stretch face
6. Create dimension B or stretch face
7. Add edge 1 and move edge or create dimensions
8. Add edge 2 and move edge or create dimensions
9. Add edge 3 and move edge or create dimensions
10 Add edge 4 and move edge or create dimensions
 Type III - plate placement between webs or top chord.
2. Select start face
3. Create thickness plate or stretch thickness
4. Create dimension A or stretch face
5. Create dimension B or stretch face
6. Insert edges (4 edge).
7. Align or place perpendicular to the axis brace
iUser
They created Advance Steel for this, but would be great to see more features in frame generator. Or perhaps an add on of Advance Steel into Inventor (like a FEA addon).
didier.spinnewyn
It should be done only to put reinforcements in the frames as on the diagram type II.
For the other diagrams, it is indeed another software that is necessary.
Cordially.
jingyi.liu
Hi @pbVE3M6
Thanks for your feedback, I think your idea is the same as below one.
https://forums.autodesk.com/t5/inventor-ideas/gussets-for-frame-generator/idi-p/4704127
Jingyi
rclement
have they added it yet? i dont see it in inventor 2022
actually i dont see alot of change here in yrs. all i know is solidworks
does alot of things inventor doesnt do.so i dont know why all these updates every year
autodesk you better wake up. you guys dont respond very quickly
colin
I just discovered that Solidworks has had a gusset tool for 4 years now. I like what I see in Inventor's better and I use its frame generator weekly, but having a gusset tool would be VERY helpful!  Creating a part number, sketching the triangle, adding a corner chf, constraining in place... iLogic could do this, but it would be SO nice if it was just part of the frame generator tool. Would save a few minutes per gusset!
