I like working on the default sheet color in the .idw/.dwg drawing format for Inventor - I feel it is easier on the eyes, especially on a large monitor.
But I often need to send a quick screen grab to share with others and the sepia color does not look good in crops or PowerPoint presentations. I would like a way to toggle the sheet color between white and the default color without having to print to PDF or similar. Also, the default tone is not available in the color swatch options, so trying to return it to default after making it white is not easy - it will be darker or lighter if you don't know the RGB numbers.
I would love a Toggle to White on/off option for the sheet I'm working on.
Thank you,
Kenny
