Default Surface Mate Constraint
The selection between mate and flush should be consistent when first using the constraint command.  As it is now, it seems to remember what selection I last used.  I don't want to, and can't remember what option I last used every time so now I have to check every time or waste time with extra clicks.  Please change this feature back to having a default position that was predictable.
3 Comments
I also think that this is unnecessary change. It does not speed up designing process in any way. Have you found a solution to this problem? Is it possible to turn this feature off?
ChrisMitchell01
Status changed to: Accepted
This is indeed being addressed for upcoming Inventor updates
dan_szymanski
This idea has been implemented within Autodesk Inventor 2020 (the legacy behavior has been returned and last used constraints no longer persist). Special thanks to everyone who cast a vote for it.
