The countersink diameter created for flat head screw clearance holes using the Inventor Hole feature dialog is too small. This causes the head of the screws to protrude above the surface of the part. This is a problem. The countersink diameter should be equal to or slightly larger than the "theoretical sharp" dimension to insure that the surface of the fastener is flush with or below the surface of the part.
![Counter Sink Dia.JPG Counter Sink Dia.JPG](https://forums.autodesk.com/t5/image/serverpage/image-id/619694i318FF96FEA165811/image-dimensions/579x309?v=v2)
![Machinerys Handbook.JPG Machinerys Handbook.JPG](https://forums.autodesk.com/t5/image/serverpage/image-id/619695i259CE7C917D9BD7C/image-size/large?v=v2&px=999)
