This example subroutine is in the API Help within Inventor. But it does not attach to the midpoint. You have to add the midpoint to the geometry intent creation. This documentation has been incorrect since at least 2016 and would be helpful if it was corrected for future developers.
This line:
Set oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve)
Needs to change to:
Set oGeometryIntent = oSheet.CreateGeometryIntent(oDrawingCurve, oMidPoint)
Code Example from API Help:
Public Sub CreateBalloon()
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oActiveSheet As Sheet
Set oActiveSheet = oDrawDoc.ActiveSheet
' Set a reference to the drawing curve segment.
' This assumes that a drwaing curve is selected.
Dim oDrawingCurveSegment As DrawingCurveSegment
Set oDrawingCurveSegment = oDrawDoc.SelectSet.Item(1)
' Set a reference to the drawing curve.
Dim oDrawingCurve As DrawingCurve
Set oDrawingCurve = oDrawingCurveSegment.Parent
' Get the mid point of the selected curve
' assuming that the selection curve is linear
Dim oMidPoint As Point2d
Set oMidPoint = oDrawingCurve.MidPoint
' Set a reference to the TransientGeometry object.
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
Dim oLeaderPoints As ObjectCollection
Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
' Create a couple of leader points.
Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 10))
Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 5))
' Add the GeometryIntent to the leader points collection.
' This is the geometry that the balloon will attach to.
Dim oGeometryIntent As GeometryIntent
Call oLeaderPoints.Add(oGeometryIntent)
' Set a reference to the parent drawing view of the selected curve
Dim oDrawingView As DrawingView
Set oDrawingView = oDrawingCurve.Parent
' Set a reference to the referenced model document
Dim oModelDoc As Document
Set oModelDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
' Check if a partslist or a balloon has already been created for this model
Dim IsDrawingBOMDefined As Boolean
IsDrawingBOMDefined = oDrawDoc.DrawingBOMs.IsDrawingBOMDefined(oModelDoc.FullFileName)
Dim oBalloon As Balloon
If IsDrawingBOMDefined Then
' Just create the balloon with the leader points
' All other arguments can be ignored
Set oBalloon = oDrawDoc.ActiveSheet.Balloons.Add(oLeaderPoints)
Else
' First check if the 'structured' BOM view has been enabled in the model
' Set a reference to the model's BOM object
Dim oBOM As BOM
Set oBOM = oModelDoc.ComponentDefinition.BOM
If oBOM.StructuredViewEnabled Then
' Level needs to be specified
' Numbering options have already been defined
' Get the Level ('All levels' or 'First level only')
' from the model BOM view - must use the same here
Dim Level As PartsListLevelEnum
If oBOM.StructuredViewFirstLevelOnly Then
Level = kStructured
Else
Level = kStructuredAllLevels
End If
' Create the balloon by specifying just the level
Set oBalloon = oActiveSheet.Balloons.Add(oLeaderPoints, , Level)
Else
' Level and numbering options must be specified
' The corresponding model BOM view will automatically be enabled
Dim oNumberingScheme As NameValueMap
Set oNumberingScheme = ThisApplication.TransientObjects.CreateNameValueMap
' Add the option for a comma delimiter
oNumberingScheme.Add "Delimiter", ","
' Create the balloon by specifying the level and numbering scheme
Set oBalloon = oActiveSheet.Balloons.Add(oLeaderPoints, , kStructuredAllLevels, oNumberingScheme)
End If
End If
End Sub
Example forum post shows it's been wrong since 2016.
