Creation Balloon why not picking MidPoint
Creation a balloon API Sample, creates Balloon from starting point of the curve.
How to change the Code so that the balloon leader point start form the mid point of the curve selected.
Please help on this code.
Thanks in Advance
M.L.Kuselan
Public Sub CreateBalloon()
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    ' Set a reference to the active sheet.
    Dim oActiveSheet As Sheet
    Set oActiveSheet = oDrawDoc.ActiveSheet
    ' Set a reference to the drawing curve segment.
    ' This assumes that a drwaing curve is selected.
    Dim oDrawingCurveSegment As DrawingCurveSegment
    Set oDrawingCurveSegment = oDrawDoc.SelectSet.Item(1)
    ' Set a reference to the drawing curve.
    Dim oDrawingCurve As DrawingCurve
    Set oDrawingCurve = oDrawingCurveSegment.Parent
    ' Get the mid point of the selected curve
    ' assuming that the selection curve is linear
    Dim oMidPoint As Point2d
    Set oMidPoint = oDrawingCurve.MidPoint
    ' Set a reference to the TransientGeometry object.
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    Dim oLeaderPoints As ObjectCollection
    Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
    ' Create a couple of leader points.
    Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 10))
    Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 5))
    ' Add the GeometryIntent to the leader points collection.
    ' This is the geometry that the balloon will attach to.
    Dim oGeometryIntent As GeometryIntent
    Set oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve)
    Call oLeaderPoints.Add(oGeometryIntent)
    ' Set a reference to the parent drawing view of the selected curve
    Dim oDrawingView As DrawingView
    Set oDrawingView = oDrawingCurve.Parent
    ' Set a reference to the referenced model document
    Dim oModelDoc As Document
    Set oModelDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
    ' Check if a partslist or a balloon has already been created for this model
    Dim IsDrawingBOMDefined As Boolean
    IsDrawingBOMDefined = oDrawDoc.DrawingBOMs.IsDrawingBOMDefined(oModelDoc.FullFileName)
    Dim oBalloon As Balloon
    If IsDrawingBOMDefined Then
        ' Just create the balloon with the leader points
        ' All other arguments can be ignored
        Set oBalloon = oDrawDoc.ActiveSheet.Balloons.Add(oLeaderPoints)
    Else
        ' First check if the 'structured' BOM view has been enabled in the model
        ' Set a reference to the model's BOM object
        Dim oBOM As BOM
        Set oBOM = oModelDoc.ComponentDefinition.BOM
        If oBOM.StructuredViewEnabled Then
            ' Level needs to be specified
            ' Numbering options have already been defined
            ' Get the Level ('All levels' or 'First level only')
            ' from the model BOM view - must use the same here
            Dim Level As PartsListLevelEnum
            If oBOM.StructuredViewFirstLevelOnly Then
                Level = kStructured
            Else
                Level = kStructuredAllLevels
            End If
            ' Create the balloon by specifying just the level
            Set oBalloon = oActiveSheet.Balloons.Add(oLeaderPoints, , Level)
        Else
            ' Level and numbering options must be specified
            ' The corresponding model BOM view will automatically be enabled
            Dim oNumberingScheme As NameValueMap
            Set oNumberingScheme = ThisApplication.TransientObjects.CreateNameValueMap
            ' Add the option for a comma delimiter
            oNumberingScheme.Add "Delimiter", ","
            ' Create the balloon by specifying the level and numbering scheme
            Set oBalloon = oActiveSheet.Balloons.Add(oLeaderPoints, , kStructuredAllLevels, oNumberingScheme)
        End If
    End If
End Sub
Hi ,
Change this line
to this
Set oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve, oDrawingCurve.MidPoint)
Hope it helps.
Hi Prakasht66,
Thanks for your reply and its working fine.
Regards
M.L.Kuselan
Tiffany_Hayden_
This was really helpful. Was the missing link to the API help Balloon Creation example. Thanks for this! @Anonymous @Anonymous
Tiffany Hayden
