Browser Folders in Part Environment
Original Author:
MattH_Work
Whilst I appreciate that we cannot move features up & down the browser without changing the Part (we are free to move components up & down in the Assembly, therefore browser folder 'restructurng' has no impact), it would be nice to have a second browser (ala the Vault browser) where we can sort, reorder, add to folders, the content of a file (group all extrusions, revolves, sketches etc)
Even if this was just a visual  display of the 'sorted' feature tree with no editing capability (maybe a right click option to 'Goto Feature' in main browser for editing) it would make it easier for finding, renaming etc
132 Comments
MattH_Work
Tags (3)
ic198
At the top of the part browser tree there are folders automatically created for Solid Bodies and Surface Bodies. Two more automatic folders for Construction Geometry (planes, points axis etc.) and Sketches would be very useful
catot
I also think more automatic folders for Sketches, Work Planes, and Work Axis would be very useful.
dan_szymanski
I would like to have the ability to create custom folders in the .ipt browser exactly like you can in an assembly.  For example, if I have a bunch of work points I should be able to highlight the points, right click and selece "Add to Folder".  Just like in an assmbly.
Rajesh.Sivaswamy
Autodesk Support
I have this request from one of our Enterprise priority support customers wanting to have the option to create folders in part browsersto group features.
hopefully I am not alone who would appreciate a chance to add a New Folder in the Browser Panel in Parts. This function exists in Assemblies and Drawings, but not in Parts. I believe this would increase lucidity and comfort in more complex parts.
jletcher
  May I ask what you will put in it?
All :))
I don't know if this is possible since part modeling requires Order of Operation execution to remain constant.
It would be good to have the ability to use sub-folders within the Solid Bodies folder within a part. This way, similar bodies could be grouped together and single action could be used for the entire group of bodies within that folder. The main application I'm thinking of is hiding or showing groups of bodies by simply right-clicking on a sub-folder and hiding/showing all it's children sub-bodies.
Tags (3)
Tags (1)
I have been working with Solidworks in which you can group commands in a folder. From aesthetic point of view, it would be great if Inventor works the same way.
As many of us, especially when developing molded parts, create part models with 100's of features, it would be very help, imho, if I could group features within "folders" as in an assembly part to simplify finding features in the side browser.....a pop-up note/description field with the folder would be even more helpful....
adding a way of inserting "regen breaks" or a frozen marker within a part file - ie "all features above this line are to be unchanged and need not be rebuilt or regenerated" might also save calc resources
Tags (1)
dan_szymanski
Status changed to: Gathering Support
This Idea has already been requested here - http://forums.autodesk.com/t5/Inventor-IdeaStation/Browser-Folders-in-Part-Environment/idi-p/3780620 Please be sure to visit the master idea, so as to not split up kudo votes. The master Idea has been accepted [US24735]. Thanks!
dan_szymanski
Status changed to: Accepted
Accepted idea [401]. Thanks!
ravikmb5
San_Escobar
+ 1, its definitely something needed.
scottmoyse
Honestly.... this functionality exists largely just by using your selection filters in the Graphics Window. Your features are already organised logically on the actual part... change your selection filter to the type of object you want to edit or inspect, then simply select it and do what you will with it.
I would much rather see ease of use improvements there, than another browser view be added. It's more intuitive and doesn't require naming or organising.
I would also like to be able to group features in the Part environment.
I will often have a set of features (extrusions, planes, fillets, etc) that are all listed together on the feature tree.
I wish I could select the group and add them to a folder.
Pro Engineer does this and calls them groups.
