Boltened Connection (lock + double click)
9 Comments
krupickaRZCS6
Yijiang.Cai
Status changed to: Accepted
@krupickaRZCS6 I suppose you are using Inventor 2025. We are working on the similar idea as below to get the insert constraint locked.
https://forums.autodesk.com/t5/inventor-ideas/toggle-rotation-lock-group-select/idi-p/12684826
Tracked as [INVGEN-70023]
Yijiang.Cai
This idea has been implemented within Autodesk Inventor 2025.1. Please review the Inventor 2025.1 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
krupickaRZCS6
But double click still doesn't work, why?
The locking setting when creating a constraint does not work.
Yijiang.Cai
@krupickaRZCS6 now double click does not support it. but we support to lock orientation from context menu command. That means there is no need to double click to edit the constraint dialog, then check the lock orientation option ON.
Hope it makes sense to you!
krupickaRZCS6
Lock orientation does not work if:
1. constraint creation is through alt + drag
2. screw joint
How is it with i-constraint, I haven't tried...
Yijiang.Cai
@krupickaRZCS6 as to double click to edit iMate constraint, it has been tracked as [INVGEN-79787]. Many thanks!
dan_szymanski
Yijiang.Cai
This idea has been implemented within Autodesk Inventor 2026.1. Please review the Inventor 2026.1 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
