Far too often, while creating assembly constraints, the need arises to constrain faces that are not currently within view, requiring the Inventor user to either use the "Select Other" right click command in order to select the desired face(s) to constrain, or to rotate the entire assembly model so that the desired faces to be constrained are in view. This is time consuming and frustrating. Rather, Autodesk can easily solve this by simply allowing "Around Corner" face highlighting during the creation of assembly constraints just like is currently available in other Inventor commands. Please add this much-needed functionality soon.
