Is there an option to zoom to sheet only?
"Home" zooms to extents, but sometimes I have geometry or internal notations lying off the sheet. Being able to consistently zoom to the size of the sheet itself would be quite handy, with added margin or without.
Solved by johnsonshiue. Go to Solution.
Sounds like you are talking about "Zoom All"
https://forums.autodesk.com/t5/inventor-forum/idw-zoom-all-does-not-zoom-sheet/td-p/6304297
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Hi! I think Zoom to Extent should do it. You are probably on 2016 or 2017 RTM build. We had a bug on that build. Please install the latest updates. The defect has been fixed a while back.
Many thanks!
