Inventor Forum
IDW zoom all does not zoom sheet
12 REPLIES 12
Message 1 of 13
tobias
1769 Views, 12 Replies
In IV 2016 when you pressed zoom all in an idw only the sheet was zoomed.
Now in IV 2017 zoom all is showing all views, also outside the drawing like autocad.
Is there a solution like zoom extends ?
Thanks.
Tobias
Tobias
The Netherlands
Inventor Pro 2025, Vault Pro 2025, AutoCad Electrical 2025.
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Tags (2)
12 REPLIES 12
Message 2 of 13
mdavis22569
in reply to: tobias
I couldn't find anything ... so I'm replying to following.
I used the zoom all to zoom in on the sheet, however I do put views outside of the sheet so I can reference certain things .. and zoom all going outside the sheet would get annoying and old.
Mike Davis
Message 3 of 13
mdavis22569
in reply to: mdavis22569
ok I added this to the ideas' station ...
I don't like this. If you have an elevation of 1000 ft ... oh you'll be in trouble with the zoom all ..
so I asked for a zoom all/ zoom sheet option.  If I'm missing something let me know
http://forums.autodesk.com/t5/inventor-ideas/zoom-all-zoom-sheet-option/idi-p/6304347
Mike Davis
Message 4 of 13
johnsonshiue
in reply to: tobias
Hi! This is indeed a change in behavior in 2017. It does not seem like the change was intended. It looks more like a bug. We are investigating how to resolve it soon.
Many thanks!
Software Test Engineer
Message 5 of 13
tobias
in reply to: johnsonshiue
Hi guys,
Thanks for all fast and positive replies. Hopefully a solution will com quickly.
Tobias
Tobias
The Netherlands
Message 6 of 13
in reply to: tobias
Hey guys i'm having the same problem however it's far worse for me, I spent 30 minutes zooming and was still nowhere close to my part. This is a project due in 2 days and this is a weeks worth of work.... please help...
Spoiler
Tags (1)
Message 7 of 13
Curtis_Waguespack
Hi jphelps1937,
Your issue is actually a different one than the one this topic/thread discusses. I would recommend that you start a new topic, and attach the file that exhibits this behavior, and someone will have a look. Don't forget to mention that you're using version 2017.
I hope this helps.
Curtis
Message 8 of 13
Mike Davis
Message 9 of 13
in reply to: Curtis_Waguespack
Thanks, will do
Message 10 of 13
johnsonshiue
in reply to: tobias
Hi Tobias! The issue has been resolved on 2017 SP1/R2. Have you installed it? If yes, please let me know if it works for you. Many thanks!
Message 11 of 13
johnsonshiue
Hi! I took a quick look at your issue. Based on the document you attached, it looks like the geometry is far away from the origin. Could you measure the distance between origin point and one of the vertices on the body? If you still cannot figure out, please send the file directly to me (johnson.shiue@autodesk.com). I would like to understand the behavior better. Many thanks!
Message 12 of 13
tobias
Hi Johnson,
Yes, I installed it already and it solved the problem.
Thanks!
Tobias
Tobias
The Netherlands
Message 13 of 13
Oh thank god!!! We just upgraded to 2017 and this issue is a BIG ONE for me, lol. Can't wait to install the fix.
thanks
