In IV 2016 when you pressed zoom all in an idw only the sheet was zoomed.
Now in IV 2017 zoom all is showing all views, also outside the drawing like autocad.
Is there a solution like zoom extends ?
Thanks.
Tobias
Solved by johnsonshiue. Go to Solution.
I couldn't find anything ... so I'm replying to following.
I used the zoom all to zoom in on the sheet, however I do put views outside of the sheet so I can reference certain things .. and zoom all going outside the sheet would get annoying and old.
ok I added this to the ideas' station ...
I don't like this. If you have an elevation of 1000 ft ... oh you'll be in trouble with the zoom all ..
so I asked for a zoom all/ zoom sheet option. If I'm missing something let me know
http://forums.autodesk.com/t5/inventor-ideas/zoom-all-zoom-sheet-option/idi-p/6304347
Hi! This is indeed a change in behavior in 2017. It does not seem like the change was intended. It looks more like a bug. We are investigating how to resolve it soon.
Many thanks!
Hi guys,
Thanks for all fast and positive replies. Hopefully a solution will com quickly.
Tobias
Hey guys i'm having the same problem however it's far worse for me, I spent 30 minutes zooming and was still nowhere close to my part. This is a project due in 2 days and this is a weeks worth of work.... please help...
Hi jphelps1937,
Your issue is actually a different one than the one this topic/thread discusses. I would recommend that you start a new topic, and attach the file that exhibits this behavior, and someone will have a look. Don't forget to mention that you're using version 2017.
I hope this helps.
Curtis
Hi Johnson,
Yes, I installed it already and it solved the problem.
Thanks!
Tobias
Oh thank god!!! We just upgraded to 2017 and this issue is a BIG ONE for me, lol. Can't wait to install the fix.
thanks
