Woodworking Box unfolding - How to
Message 1 of 9
Hello everyone, I am looking for a way to unfold a specific part. I know it is doable in real life, so I assume Inventor is able to do it too, but I can't seem to find a way to make it work. Please help.
I tried making an unfolded profile of the part, then adjusting the bend radius to .001 so it would make a .001 inside radius and then a .002 outside radius, but it doesn't work like that according to Inventor logic, it makes it .751, so then I tried manual radius of .001 and .002, still wont work. Then I tried drawing lines on a back face and use the unfold function... still not working. And yes, I used the offset function with a .001 offset to make sure the part wouldn't "break" from what I know of Inventor's behaviour. I tried various offsets and radii too, like .100 offsets with adjusted radius, still wouldn't work.
I would appreciate if somebody could link me a file that works.
Replies (8)
Message 2 of 9
robertast
@Anonymous
You wanted it?
unfolding
Message 3 of 9
swalton
Are you trying to make a v-groove bend?
Inventor's sheetmetal is limited to parts with uniform thickness.
You might try some of the workarounds in the following posts
https://forums.autodesk.com/t5/inventor-forum/can-i-create-a-v-groove-at-sheet-metal-fold-line/td-p/...
https://forums.autodesk.com/t5/inventor-forum/panels-with-v-groove-possible/td-p/6817180
https://forums.autodesk.com/t5/inventor-forum/how-to-model-acm-sheet-metal/td-p/3198662
or vote for the following ideas:
https://forums.autodesk.com/t5/inventor-ideas/enhancement-for-sheet-metal-v-groove-bending/idi-p/870...
https://forums.autodesk.com/t5/inventor-ideas/support-for-v-groove-and-backrouting-in-sheet-metal-co...
Steve Walton
Inventor 2025
Vault Professional 2025
Message 4 of 9
robertast
In this version, which I proposed and used, it is not necessary to imitate a V-shaped groove, it is only necessary to draw the shape of the groove with the shape of the correct - a blunt cutter. Use the bent part in the assembly, and a copy with the suppressed bend for drawings and for transfer to the CNS
Message 5 of 9
You are using a newer version than me so unfortunately I can't look at your steps properly, but I should be able to replicate it pretty easily. I didn't know there was yet another bend function like this (that's like the 3rd or something Inventor has !)
Thank you very much!
Message 6 of 9
robertast
@Anonymous
What version do you have? in the evening I can do for 2020
Message 7 of 9
Sorry for the long delay, had internet issues. 2016.
Message 8 of 9
robertast
for 2016 I have no opportunity to make a sample. If you do not get what you want yourself. Write I'll make at least a video
Message 9 of 9
Would 2019 be better? I could read that version,
