& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Has anyone the same issues as I have:
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Hi Arthur,
A few things I would do. Make sure all critical Windows updates and the latest graphics driver are installed. Use Microsoft Disk CleanUp to remove cached files. Lastly, run Inventor as admin.
Many thanks!
Thanks @johnsonshiue for your support on this bu I have tried all these things, unfortunately this did not solve the issue. Even now after uninstall Inventor 2026 the dwg file keeps be the problem maker.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Does anybody have a solution?
@johnsonshiue @CGBenner @ChrisMitchell01 @dan_szymanski
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Hi Arthur,
Based on the prior discussions, I can share the additional ideas. Please try disabling all non-Autodesk Add-Ins. Use Microsoft Disk Cleanup to remove cached files. Take a look at the following article.
Many thanks!
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
