Message 1 of 9
06:12 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to make my own skis but when I've created a 3D modell that's looks good and I create a Flat Pattern the dimensions are changed. For example the tip width shoud be 142mm, tail 130mm, waist 105mm but in Flat Pattern the tip width is 144.213mm, tail 130.858mm, waist 104.709mm. These dimensions should not be affected, it's only the length axis dimensions that should be affected.
Why is the dimensions changed when a Flat Pattern is created and how to evade this problem?
