Hello, im struggling with sweeping this profile around an elipse. Am i doing something wrong ?
The ipt file is attached below.
Solved by JDMather. Go to Solution.
Wouldn't the geometry self-intersect?
Have you installed all Updates for 2023?
Is your Sketch2 fully defined?
Did you intend for these lines to be Tangent to the circles?
I suspect your Design Intent could used Place Fillet Features rather than these circles?
Missing a lot of Tangents?
Did you intend for these to be lines or to be arcs?
Exactly what are you attempting to model?
Do you have a picture of something similar from the real world?
Is something like this what you are attempting to model?
Sorry somehow i either missed the half of your message, or you edited at the time i wrote an answer.
Im trying to model a bath tub seating something like this in the picture below:
@Nauris47 wrote:
I have installed all the updates.
When did you Update?
iProperties would seem to indicate otherwise.
@Nauris47 wrote:
Yes the lines are tangent to the circles.
They aren't lines.
They are arcs and they aren't Tangent? (not even close)
@Nauris47 wrote:
Even if i fully define the sketch, it won't let me sweep the profile.
Attach your file here with fully defined sketches and I will demonstrate the solution.
@Nauris47 wrote:
Yes @JDMather, exactly. Could you tell me what is the problem with my sketch?
Missing Tangent Constraints and logical dimensions (that can be measured in the real world).
@Nauris47 wrote:
Here is the fully defined sketch.
How will this dimension be measured in the real world?
Is this line supposed to be Tangent?
So i fixed all dimensions so that they are "whole", without any decimals. I drew the lines and put tangent constraint to lines and circles.
@Nauris47 wrote:
So i fixed all dimensions ...
No new file Attached???
Let's try again.
Is the line shown in red supposed to be Tangent at both circles? (It isn't tangent at the R75 circle.)
What is the purpose of the 50mm line? (Don't erase it - we will need it, I just want to know where the 50mm dimension came from).
Yes the red line should be tangent to both circles, and the 50mm line was a left over from fixing a sketch, i just realised it now, as it was hiding on dimension lines.
@Nauris47 wrote:
Yes the red line should be tangent to both circles, ...
Attach file here with line tangent to both circles.
@JDMather wrote:
Let's try again.
here is the file with 50mm line, it came from before sketch, i just drew this line so i know where the center point of the circle will be.
