Inventor Forum
Why cant i sweep this profile ?
24 REPLIES 24
Message 1 of 25
Nauris47
1044 Views, 24 Replies
Hello, im struggling with sweeping this profile around an elipse. Am i doing something wrong ?
The ipt file is attached below.
24 REPLIES 24
Message 2 of 25
JDMather
in reply to: Nauris47
@Nauris47
Wouldn't the geometry self-intersect?
Have you installed all Updates for 2023?
Is your Sketch2 fully defined?
Did you intend for these lines to be Tangent to the circles?
I suspect your Design Intent could used Place Fillet Features rather than these circles?
Missing a lot of Tangents?
Did you intend for these to be lines or to be arcs?
Exactly what are you attempting to model?
Do you have a picture of something similar from the real world?
Is something like this what you are attempting to model?
Message 3 of 25
Nauris47
in reply to: JDMather
Thanks for the reply @JDMather,
I have installed all the updates.
Yes the lines are tangent to the circles. I dont think the geometry should self-intersect.
Even if i fully define the sketch, it wont let me sweep the profile.
Message 4 of 25
Nauris47
Sorry somehow i either missed the half of your message, or you edited at the time i wrote an answer.
Im trying to model a bath tub seating something like this in the picture below:
Message 5 of 25
Nauris47
Yes @JDMather, exactly. Could you tell me what is the problem with my sketch ?
Message 6 of 25
JDMather
When did you Update?
iProperties would seem to indicate otherwise.
Message 7 of 25
JDMather
They aren't lines.
They are arcs and they aren't Tangent? (not even close)
Message 8 of 25
JDMather
@Nauris47 wrote:
Even if i fully define the sketch, it won't let me sweep the profile.
Attach your file here with fully defined sketches and I will demonstrate the solution.
Message 9 of 25
JDMather
Missing Tangent Constraints and logical dimensions (that can be measured in the real world).
Message 10 of 25
Nauris47
Here is the fully defined sketch.
Message 11 of 25
JDMather
How will this dimension be measured in the real world?
Is this line supposed to be Tangent?
Message 12 of 25
Nauris47
So i fixed all dimensions so that they are "whole", without any decimals. I drew the lines and put tangent constraint to lines and circles.
Message 13 of 25
JDMather
@Nauris47 wrote:
So i fixed all dimensions ...
No new file Attached???
Message 14 of 25
Nauris47
Here is the file sir.
Message 15 of 25
JDMather
Let's try again.
Is the line shown in red supposed to be Tangent at both circles? (It isn't tangent at the R75 circle.)
What is the purpose of the 50mm line? (Don't erase it - we will need it, I just want to know where the 50mm dimension came from).
Message 16 of 25
Nauris47
Yes the red line should be tangent to both circles, and the 50mm line was a left over from fixing a sketch, i just realised it now, as it was hiding on dimension lines.
Message 17 of 25
JDMather
@Nauris47 wrote:
Yes the red line should be tangent to both circles, ...
Attach file here with line tangent to both circles.
Message 18 of 25
Nauris47
Here it is, i deleted the 50mm as it was a leftover i missed.
Message 19 of 25
JDMather
@JDMather wrote:
Let's try again.
Message 20 of 25
Nauris47
here is the file with 50mm line, it came from before sketch, i just drew this line so i know where the center point of the circle will be.
