Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
At the last versions the command curve bridge ( in line option) is missing ?
Why Autodesk "killed" this option ?
Hi
It is still there.
Which version your screenshot ?
Exactly what you wrote in your initial post.
The screenshot is from the latest version, Inventor 2021.
What version are you using (including Update number)?
Hi
I don't have this option at 2020 version (my previous screenshot)
I found it at 2021 , but also missing at 2018
You didn't answer my question, so let's try this.
Attach a *.ipt file here.
iProperties of the part you attached indicates that you have not installed Update 2.2 for 2020.
If you attach a *.ipt file from you 2018, I can check the iProperties for that version as well.
Bridge Curve is part of the "Mold Design" add-in. Load the add-in and it should appear.
Hi
I suspect that the problem is in the ADD IN , the Mold wasn't one of them 😀
Why must you load the Mold Design Add-in to access the Bridge Curve tool? Would only mold designers need this tool?
I know I tried to use it, but had unloaded Mold Design previously. My search for the missing command brought me to this Forum thread and solution.
