where is the command curve bridge ?
eladm
Message 1 of 13
eladm
Hi
At the last versions the command curve bridge ( in line option) is missing ?
Why Autodesk "killed" this option ?
Replies (12)
Message 2 of 13
JDMather
It is still there.
Message 3 of 13
eladm
Hi
Where ?
Message 4 of 13
eladm
Hi
Which version your screenshot ?
regards
Message 5 of 13
JDMather
Exactly what you wrote in your initial post.
The screenshot is from the latest version, Inventor 2021.
What version are you using (including Update number)?
Message 6 of 13
eladm
Hi
I don't have this option at 2020 version (my previous screenshot)
I found it at 2021 , but also missing at 2018
Message 7 of 13
JDMather
You didn't answer my question, so let's try this.
Attach a *.ipt file here.
Message 8 of 13
eladm
Hi
I attached my templete , this is standart.ipt
mayabe it is add in I canceled
Message 9 of 13
JDMather
iProperties of the part you attached indicates that you have not installed Update 2.2 for 2020.
http://manage.autodesk.com
If you attach a *.ipt file from you 2018, I can check the iProperties for that version as well.
Message 10 of 13
eladm
Hi
attached 2018
Message 11 of 13
Scott_Parker
Bridge Curve is part of the "Mold Design" add-in.  Load the add-in and it should appear.
Scott Parker
Principal Software Engineer
Message 12 of 13
eladm
Hi
I suspect that the problem is in the ADD IN , the Mold wasn't one of them 😀
Message 13 of 13
JBerns
Why must you load the Mold Design Add-in to access the Bridge Curve tool? Would only mold designers need this tool?
I know I tried to use it, but had unloaded Mold Design previously. My search for the missing command brought me to this Forum thread and solution.
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
