Inventor Forum
Folded part and flat pattern.
4 REPLIES 4
533 Views, 4 Replies
Hello, i made a metal drawer using sheet command. I used flange to make sides, but one side is a little bigger i extended it using olso flange command. (you can see it in first foto). In 3D everything looks okay for me, but if i go to flat pattern, i see strange corners (second foto). if i want to cut the metal and later to bend it, will it be a problem? Inventor doest give me any error when i make flat pattern. Iam new to sketching, so please give me advice. Thank you.
4 REPLIES 4
JDMather
Attach your *.ipt file here.
in reply to: JDMather
IgorMir
Hi Jonas;
It appears - there is a problem with the Flat Pattern module. I can reproduce the error easily. The Flat Pattern should look like the one in the attached file. Why there is an error in the Flat Pattern in your file - I don't know. The model is legitimate, as far as I am concerned.
Cheers,
Igor.
Web: www.meqc.com.au
johnsonshiue
Hi! The flat pattern does not look right, though the default Corner relief was set to Tear. It does look like Tear, However, if I change it to a different type, the corner release looks the same, which is wrong.
Many thanks!
Software Test Engineer
