When opening a part, the part is off the screen.
ToddPig
ToddPig
I have multiple parts (all similar to the attached) that when I open them, the screen is blank.  I have to "zoom to fit" to see the part.  This does not happen most of the time on other parts.
What I have already tried:
1. Checked each sketch for geometry that might be "out-in-space"
2. Checked each block for geometry that might be "out-in-space"
3. Zoomed in, then save, close, and reopen.
4. Restarted Inventor
For Reference:
The thumbnail image in Vault shows the part.
I saved the part as an IGES file and opened it in SW.  Upon opening, it zoomed to fit the screen.  When I closed and reopened, it again was full screen.
Thanks in advance
Todd
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
hugo.trepanier
Just change these 2 values in the document settings. enter 0 and 0 and save. All will be ok after
Hugo Trepanier
Autodesk MSD Application Specialist
JDMather
You can also set the view however you would like it to be and then right click on the View Cube and Set Current View as Home Position.
ToddPig
@JDMather - As always, Thanks!!
Any idea how I can prevent this from happening?
Inventor 2018
iParts = iHeadache
ToddPig
@hugo.trepanier - Thanks.
Inventor 2018
iParts = iHeadache
kschumacher
Isn't there a setting somewhere in Application Option so it works "globally" ?
Seems I recall doing it before but it was eons ago.
Ken -
