Adding Components to the Library
I need to add the following parts to the library
Bearing Housings (Plumber Block Housing and flanged housing) and also Shaft locking devices or Bikons
First, I need to know that is there any place so I can download at least some of the sizes? I tried SKF for bearing housing but it did not work
Second, How can I add them to the library?
Thank you
Mark.Lancaster
@Anonymous
Library as in content center library or library as outlined in your active Inventor project file?
Mark Lancaster
hello
library in content center
Mark.Lancaster
@Anonymous
You will have to make your own read/write content center and then start populating it from there...  Do you have a custom read/write library?
https://synergiscadblog.com/2014/03/17/working-with-autodesk-inventor-content-center-part-2-of-3/
Mark Lancaster
blandb
You can try dodge bearing website and ringfeder. They have models.
Autodesk Certified Professional
