I have a part named Layout where I have some sketchs I want to use in other parts design. The problem is that, in some of those sketchs, some construction lines become normal. I can resolve it manually but I want to know if there is any problem that could be the reason for that behaviour or how to avoid it
Hi! The way I understood how it should work is like this. When you first derive the sketch, the line types are carried over from the source sketch to the derived sketch. However, if you edit the derived sketch and change the line type, the change will not be overridden on update.
I assume the derived sketch you have was created as such. If you notice a behavior not following what I mentioned here, there could be a bug. Please share an example so forum experts can take a look and comment further.
Many thanks!
Hi @johnsonshiue ,
This is the behavior I see, with a construction lines and a spline.
The Master Part is made by:
The Derived Part is created with:
Why is this the case, is this a bug?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Hi Arthur,
This has been discussed before. Indeed, the behavior is a limitation for now. We are unblocking it. The latest Alpha build actually allows you to drive the linetype from the source sketch to the derive sketch. If you are interested, please sign up Inventor Feedback Community (https://autode.sk/InventorBeta) to try it on an install-free, browser-based environment.
Many thanks!
This means that it has been solved within the new Release of Inventor 2022?
Arthur Knoors
Hi Arthur,
I cannot comment on exact release. All I can say is that it has been fixed in our latest internal build targeting the future release.
Many thanks!
Unfortunately it has still not been implemented even in Inventor 2023. 😞
Hi Peter,
It is available on 2023. Please go to Tools -> App Options -> Part -> Make/Derive/Shrinkwrap default -> check or uncheck "Link sketch formatting from source component."
Many thanks!
