Inventor Forum
Weldment Groove problem
2 REPLIES 2
Marcin.Szklarek
415 Views, 2 Replies
Hi!
I am trying to apply groove welds to corners and I noticed that although the corners are symmetric Inventor computes them in a different way. Any reasons why? Some  are modeled properly (symmetrical) other not .
2 REPLIES 2
Hi Marcin,
This is a tough spot to weld. I tweaked the sheet metal part a bit. The result is not 100% you were expecting but it is the best I can come up for the given geometry.
Many thanks!
Software Test Engineer
Thank you. The top ones i have done the sameway ( didn't want suggest the solution). But the problem are the bottom ones where the fold is and that trick does not work there. Tough life will have to avoid that one.
Technology Administrators
