Hi!
I am trying to apply groove welds to corners and I noticed that although the corners are symmetric Inventor computes them in a different way. Any reasons why? Some are modeled properly (symmetrical) other not .
Solved by johnsonshiue. Go to Solution.
Hi Marcin,
This is a tough spot to weld. I tweaked the sheet metal part a bit. The result is not 100% you were expecting but it is the best I can come up for the given geometry.
Many thanks!
Thank you. The top ones i have done the sameway ( didn't want suggest the solution). But the problem are the bottom ones where the fold is and that trick does not work there. Tough life will have to avoid that one.
