Inventor Forum
Weld error
4 REPLIES 4
505 Views, 4 Replies
Weld error
cant do a fillet weld today.. it worked fine yesterday... i dont know why this need to be so difficult.. i go and weld in real life quicker and easier than trying to weld in inventor.. sorry just pissed of at wasting time. and this is the 3rd time i have had to re write this post... as it keeps disappearing ffs
see stuff below
4 REPLIES 4
TheCADWhisperer
@Anonymous wrote:
...i go and weld in real life quicker and easier than trying to weld in inventor..
From my one class in welding - I came to the determination that welding is an art.  My art did not look very aesthetically pleasing.
What size weld bead are you attempting? The faces are limited to 5mm.
Also - the Sketch 5 location for holes is not fully defined and the holes are off-center.
TheCADWhisperer
johnsonshiue
Hi! The fillet weld should work. Did you select all faces in one selection? The fillet weld requires two sides of faces. Please share a video or describe the steps leading to the error.
Many thanks!
Software Test Engineer
in reply to: TheCADWhisperer
Thank you i realize now that it was because i changed the material thickness from 6mm to 5mm and the end of the day and when i started in the morning the weld was in error.. i still have so much to learn, and not the time to do it.
really appreciate the video cheers
Technology Administrators
